Infocus LP120 Ultra-Portable Projector Review (pics, specs)
by Reads (10,942)
Infocus LP120 Projector Review
by Jesse A. Francis, Michigan USA
Introduction
Product Overview
Picture Quality
Connectivity
Zoom/Lens
Form Factor
Size & Weight
Other
Noise & Heat
First Glance
The first thing you’ll notice about the Infocus LP120 projector is it’s wonderfully small form factor. This mobile projector is very small (2.05″ (H) x 3.69″ (L) x 9.75″ (W)) and light weight (1.98lbs). The LP120 could fit inside of a laptop carrying case, which reduces the amount of baggage required for travel. But can a projector with such small stature be able to perform to task? Read on to find out! Next >>
Specifications (from www.infocus.com)
GENERAL
Native Resolution – XGA 1024 x 768
Brightness – 1000 max ANSI lumens
Contrast Ratio – 2000:1 full on/full off
Display Technology – DLP by Texas Instruments: 0.7″ XGA 12 DMD DDR
Computer Compatibility – SXGA, XGA, SVGA, VGA, Macintosh
Video Compatibility: Full NTSC, PAL, SECAM
Digital Keystone Correction: 7.5 vertical correction
Aspect Ratio – 4:3
SIZE
Dimensions – 2.05″ (H) x 3.69″ (L) x 9.75″ (W) – 5.21 cm (H) x 9.37 cm (L) x 24.77 cm (W)
Weight – 1.98 lbs/0.9 kg
INPUT
Computer (M1-DA)
Video (S-Video; RCA via standard S-Video to RCA input adapter)
Audio (3.5 mm mini jack)
OTHER
Number of Colors – 16.7 million
H-Synch Range – 15 – 100 kHz
V-Synch Range – 43.5 – 130 Hz
Pixel Clock – Digital 112 MHz (max); analog 135 MHz (max)
Image Offset – 112%
Projection Lens – Zoom lens with manual focus and manual zoom adjust
Throw Ratio – 1.8 – 2.1:1 (typical)
Minimum Projection Distance – 1.5 m (maximum distance 5.0 m)
Image Size (diagonal) – 2.9′ to greater than 11.5’/0.9 m to greater than 3.5 m
Projection Methods – Front and rear
Audio – 1-watt speaker
Control – Projector keypad; IR remote control; wired control through USB
Lamp – 120W UHP / 2000 (typical)
Power Consumption – 150 watts
Power Supply – 100V – 240V at 50 – 60 Hz
Operating Temperature – 5 – 40 C at sea level (0′ – 10,000′), 41 – 104 F
Menu Languages – English, Norwegian, Spanish, Italian, Portuguese, German, French, Chinese (simplified), Chinese (traditional), Japanese, Russian, Korean
Audible Noise – 37dB
Approvals – FCC A (US/Canada), S-JQA (Japan), PSE (Japan), CCC (China), IRAM (Argentina), GOST (Russia), UL & cUL (US/Canada), TUV GS (Germany), NOM (Mexico), MIC (Korea), C-Tick (Australia)
Lamp Warranty – 90 days or 500 hours, whichever comes first
Product Warranty – 2 years: parts and labor
Accessory Warranty – 1 year
