Infocus LP120 Projector Review (Noise & Heat)
by Reads (2,788)
Introduction
Product Overview
Picture Quality
Connectivity
Zoom/Lens
Form Factor
Size & Weight
Other
Noise & Heat
Noise
The form factor of this projector is so small that the heat has to be dissipated through a higher speed fan. As soon as you turn on the projector, you can hear a low whirring noise.  The noise is rated at 37dB, while it is noticeable, it is not enough to detract attention from your presentation or whatever else you may be viewing.
Heat
This projector gets hot. The small form factor requires heat to be passively radiated along with the cooling fan in order for proper cooling. While being noticeably hotter than other larger projectors; the LP120 is similar to other compact projectors for heat. Next>>
