Infocus LP120 Projector Review (Connectivity)
by Reads (3,140)
Introduction
Product Overview
Picture Quality
Connectivity
Zoom/Lens
Form Factor
Size & Weight
Other
Noise & Heat
Connectivity
The Infocus LP120 supports the following input:
Computer (M1-DA)
Video (S-Video; RCA via standard S-Video to RCA input adapter)
Audio (3.5 mm mini jack)
For visual purposes:
The projector allows you to input your video source via almost any imaginable method. If the main inputs are not available (S-video/Computer), the projector has included an adapter that allows RCA input. If you are presenting a presentation that includes audio, input is also possible for usage of the onboard sound. This is great if you have a laptop with weak sound output (like most laptops!). Next >>
