Fujitsu Lifebook S6210 Review: Wireless and Battery
by Reads (4,209)
      • 7.71
Table of Contents
OVERVIEW and Introduction
Reasons for Buying
Where and How Purchased
How the Laptop Comes Packaged
Form and Design
Processor and Performance
Keyboard and Touch-pad & Input and Output Ports
Operating System and Software
Customer Support
Praises and Complaints
The built in wireless feature of this laptop simply rocks. I am able to get great reception–I can not only pick up my own wireless signal, but also 5 to 6 other wireless networks in the neighborhood. There is a convenient on/off switch on the back of the computer (as shown in Keyboard and Touch-pad & Input and Output Ports section), which allows for a quick and easy way to enable/disable the wireless card. Turning the wireless adapter off is a great way for extending battery life!
The battery featured in the Fujitsu S6210 is a Lithium ion, 10.8 volt, 440mAh, 47.5 Watt Hour battery. What does that translate into? It translates into 4 hours of continuous use. After fully charging the battery I surfed the internet and did various other CPU non intensive tasks for approx. 4 hours. This time decreases dramatically if you are utilizing the full power of the CPU. A great feature of the Fujitsu laptop is that the keyboard has a direct and quick way to turn down the brightness of the screen, which extends battery life.
Next, the Operating System and Software. Next Page>>
