Fujitsu Lifebook S6210 Review: Praises and Complaints
by Reads (5,252)
      • 7.71
Table of Contents
OVERVIEW and Introduction
Reasons for Buying
Where and How Purchased
How the Laptop Comes Packaged
Form and Design
Processor and Performance
Keyboard and Touch-pad & Input and Output Ports
Wireless and Battery
Operating System and Software
Customer Support
Praises
To start with, the Crystal View display is excellent; It will leave even the pickiest screen guru in awe of its beauty, sharpness, and elegance. It is simply unparalleled by any other laptop display. The features on this laptop for the price is hard to beat too. For under $1,600 you get a fast Centrino processor, the sweet display, an adequate amount of hard disk space and ram, dvd burner, wireless connectivity, fire wire, usb, memory card reader, etc–it’s a great deal. To top it all off, the technical support is the cats pajamas! You wont find yourself waiting on hold with Fujitsu.
Complaints
There is only one complaint that I have with this system. The system information display is an LCD that lays flat in front of the screen (as pictured above). It isn’t backlit so reading this in low light conditions is hopeless. If Fujitsu manages to update this problem, it’d give this laptop almost a perfect score.
To the Conclusion. Next Page>>
