Averatec AV2575 Review
by Reads (27,858)
The Averatec 2575 is a thin and light 12.1" widescreen notebook that packs a dual core AMD processor, DVD burner, and super-bright WXGA screen in an ultra-portable sized package. This notebook aims to offer great entertainment and multimedia performance in a small form factor for road warriors who demand a little more from their notebooks than standard internet browsing or document typing. Read on to see if this notebook lives up to its claims, and see how it compares to other notebooks in the same category.
Our review unit of the Averatec AV2575 has the following configuration:
  • AMD Turion 64 X2 TL-64 (2.2GHz)
  • Windows Vista Home Premium 32-bit
  • 2GB DDR2-667 dual-channel RAM (2 x 1GB)
  • 250GB 5400RPM Hard Drive
  • 12.1" WXGA (1280×800) Glossy
  • ATI RS690T Integrated Graphics
  • Super Multi DVD Burner
  • Atheros AR5007EG 802.11b/g
  • Built-in 1.3 megapixel webcam and microphone
  • Ports: 3 USB, Kensington Lock Slot, LAN, Headphone/Mic, VGA, SD Card Reader, ExpressCard/54, 10/100 LAN
  • Size: 12.88 x 9 x 1.0/1.53"
  • Weight:
    • Notebook 4lbs 0.8oz
    • AC Adapter 13.5oz
  • 65w AC Adapter
  • 4-Cell Battery (14.4v, 2500mAh)
  • Warranty: 1 Year standard, 6 months on battery
  • Price: $1,099.99
For a 12" ultraportable notebook the Avertac AV2500 series is somewhat larger than you would expect, more in line with a 13.3" notebook. Some of this size you can see around the screen bezel where there is almost an inch of space on each side of the LCD. On the keyboard side this extra space is used to make a larger keyboard than you would usually see on a 12" notebook.
Build quality is excellent, having a very rigid chassis with minimal flex. The screen frame is very strong, although it doesn’t keep away all the ripples on the screen when you try to flex it or press on the back of the cover. The screen hinges gave a good amount of tension and usually required the use of two hands to open up the notebook.
The screen latching design was one element that stuck out for me, where it was the simple design that I loved. It is a latchless system that uses magnets and the hinge tension to keep the notebook lid closed. Unlike hinge tension only setups, the magnets keep the lid firmly closed, and give a satisfying click when "latched".
One area that has us concerned with the screen cover is the glossy finish did not hold up as well as we had expected, and scuffed very easily from day-to-day use. If you are looking at purcashing one of these notebooks, I would put thought into a notebook case with a soft interior to keep the screen cover perfectly glossy from day one.
Display
The display is a glossy 12.1" WXGA screen that is advertised as "super-bright". I wouldn’t go as far as saying it is ultra bright, as it ranks right on average with other glossy screens we have come across. Colors are bright and vibrant, and the backlight is very even and consistent with minimal backlight leakage. I would rate it pretty well for viewing images or watching movies, although movies might be difficult away from an outlet.
Viewing angles of the screen were average, with great horizontal range, but limited vertical range. Tilting the screen forward or back will wash out or invert the colors once you go past the screens 10-15 degree sweet spot.
Unlike many 12" notebooks, the keyboard on the Averatec is far from cramped, and is spaced out like a fullsize keyboard you would find on a 14" or 15" notebook. All of the keys are full-size, with no ultra-slim function or ctrl keys found anywhere. This is a huge plus for many people who can’t stand a cramped notebook for extended periods of typing.
Keyboard quality is excellent, with great travel and key feedback. When pressed, each key gives off a nice quiet metallic click. Key wobble is minimal, on par with my ThinkPad keyboard.
The touchpad is a Synaptics design model, with great sensitivity and of normal size. Measuring in at 2.46 x 1.76", it is actually larger than the one found on my 15" T60 ThinkPad. Touchpad button feedback is shallow, and gives off a soft click when pressed.
Audio performance is average for a notebook of this size, considering the speakers are the size of pennies. For watching movies or music without caring about perfect audio quality or bass they are fine, but I would recommend using headphones for extended listening if you can. The headphone jack on this notebook provided clear and static-free audio, and could output high enough volume to hurt your ears.
System performance is rated average, running standard applications with ease, but really lacking the performance to play older games with minimal settings. While most notebooks of this size aren’t gaming machines by any stretch of the imagination, the ATI integrated graphics didn’t perform as well as Intel integrated graphics. Performance in regular tasks, or multimedia content was stellar, as it did not weigh as heaviliy on the graphics chipset. HD Movie content or DVD movies played with ease. Office productivity software loaded without lag, so handling office loads while traveling would not be a problem.
Benchmarks for this system are listed below:
wPrime is a program that forces the processor to do recursive mathematical calculations, the advantage of this program is that it is multi-threaded and can use both processor cores at once, thereby giving more accurate benchmarking measurements than Super Pi. Lower scores indicate better performance.
Notebook / CPU wPrime 32M time
Averatec 2575 (Turion 64 X2 TL-64 @ 2.2GHz) 37.705s
Dell Inspiron 1525 (Core 2 Duo T7250 @ 2.0GHz) 43.569s
Dell XPS M1530 (Core 2 Duo T7500 @ 2.2GHz)
37.485s
Portable One SXS37 (Core 2 Duo T7250 @ 2.0GHz) 41.908s
Sony VAIO NR (Core 2 Duo T5250 @ 1.5GHz) 58.233s
Toshiba Tecra A9 (Core 2 Duo T7500 @ 2.2GHz) 38.343s
Toshiba Tecra M9 (Core 2 Duo T7500 @ 2.2GHz) 37.299s
HP Compaq 6910p (Core 2 Duo T7300 @ 2GHz) 40.965s
Sony VAIO TZ (Core 2 Duo U7600 @ 1.20GHz) 76.240s
Zepto 6024W (Core 2 Duo T7300 @ 2GHz) 42.385s
Lenovo T61 (Core 2 Duo T7500 @ 2.2GHz) 37.705s
Alienware M5750 (Core 2 Duo T7600 @ 2.33GHz) 38.327s
Hewlett Packard DV6000z (Turion X2 TL-60 @ 2.0GHz) 38.720s
Samsung Q70 (Core 2 Duo T7300 @ 2.0GHz) 42.218s
Acer Travelmate 8204WLMi (Core Duo T2500 @ 2.0GHz) 42.947s
Samsung X60plus (Core 2 Duo T7200 @ 2.0GHz) 44.922s
Zepto Znote 6224W (Core 2 Duo T7300 @ 2.0GHz) 45.788s
Samsung Q35 (Core 2 Duo T5600 @ 1.83GHz) 46.274s
Samsung R20 (Core Duo T2250 @ 1.73GHz) 47.563s
3DMark06 comparison results for graphics performance (higher scores are better):
Averatec 2575 (2.2 GHz AMD Turion 64 X2 TL-64, ATI RS690T) 377 3DMarks
Dell Inspiron 1525 (2.0GHz Intel T7250, Intel X3100) 545 3DMarks
Sony VAIO NR (1.5GHz Intel Core 2 Duo T5250, Intel X3100) 504 3DMarks
Dell XPS M1530 (2.20GHz Intel T7500, Nvidia 8600M GT 256MB) 4,332 3DMarks
Dell Inspiron 1520 (2.0GHz Intel T7300, NVIDIA 8600M GT) 2,905 3DMarks
Dell XPS M1330 (2.0GHz Intel Core 2 Duo T7300, NVIDIA GeForce Go 8400M GS 128MB) 1,408 3DMarks
Samsung Q70 (2.0GHz Core 2 Duo T7300 and nVidia 8400M G GPU) 1,069 3DMarks
Asus F3sv-A1 (Core 2 Duo T7300 2.0GHz, Nvidia 8600M GS 256MB) 2,344 3DMarks
Alienware Area 51 m5550 (2.33GHz Core 2 Duo, nVidia GeForce Go 7600 256MB 2,183 3DMarks
Fujitsu Siemens Amilo Xi 1526 (1.66GHz Core Duo, nVidia 7600Go 256 MB) 2,144 3DMarks
Samsung X60plus (2.0GHz Core 2 Duo T7200, ATI X1700 256MB) 1,831 3DMarks
Asus A6J (1.83GHz Core Duo, ATI X1600 128MB) 1,819 3DMarks
PCMark05 measures overall notebook performance (higher scores are better):
Averatec 2575 (2.2 GHz AMD Turion 64 X2 TL-64, ATI RS690T) 3,143 PCMarks
Dell Inspiron 1525 (2.0GHz Intel T7250, Intel X3100) 4,149 PCMarks
Dell XPS M1530 (2.20GHz Intel T7500, Nvidia 8600M GT 256MB) 5,412 PCMarks
Dell Inspiron 1520 (2.0GHz Intel T7300, NVIDIA 8600M GT) 4,616 PCMarks
Dell XPS M1330 (2.0GHz Intel Core 2 Duo T7300, NVIDIA GeForce Go 8400M GS) 4,591 PCMarks
Fujitsu N6410 (1.66GHz Core Duo, ATI X1400) 3,487 PCMarks
Alienware M7700 (AMD Athlon FX-60, Nvidia Go 7800GTX) 5,597 PCMarks
Sony VAIO SZ-110B in Speed Mode (Using Nvidia GeForce Go 7400) 3,637 PCMarks
HDTune results:
Post selection on the 12.1" Averatec AV2575 was more than adequate, having a full lineup of expansion slots, optical drive, and ports. Have a builtin optical drive is also a huge perk on a notebook of this size.
Front: Headphone/Mic, Indicator Lights
Rear: Battery
Right: ExpressCard/54, SD-Card Reader, 2 USB, CPU Vent, AC Power
Left: Kensington Lock Slot, VGA, LAN, 1 USB, Optical Drive
With screen brightness at 70 percent, power profile set to balanced, the notebook came in at 2 hours and 10 minutes of battery life on the standard battery (14.4v, 2500mAh). An extended battery should offer much great battery life, which would be required if you plan on watching movies on a flight, or anywhere away from a power outlet.
Temperatures were very tame on this notebook, never reaching uncomfortable levels even when running benchmarks. Fan noise was minimal at high speed during benchmarks, and barely perceptible when idling. For a quiet room you should not have any problem blending into the background, unlike that guy in front of you with his gaming notebook that sounds like a leaf blower.
The heat overlay picture below shows the notebook after it has been on for a few hours during the work day. The room temperature during this test was 73 degrees Fahrenheit.
The Averatec 12.1" ultraportable AV2575 notebook offers a great value at a price of $1,099. While it is heavier than other notebooks of this size, the build quality, keyboard, touchpad, and thermal performance is excellent. The one area that I could see some improvement on is battery life, which hopefully an extended battery would help with.
  • Clean basic design
  • Durable, rigid chassis
  • Low noise and heat
  • Great keyboard
  • Sluggish gaming performance
  • Glossy finish scuffs easily
The Averatec AV2575 will be available soon with more information available on the Averatec website.
