Samsung ML-5512nd Review: First Look
by Reads (1,648)
The Samsung ML-5512nd is a high functioning monochrome laser printer targeted at range of businesses thanks to quick print speeds, a large maximum monthly duty cycle and a variety of finishing options that help businesses customize their experience.
Today, we’ll be taking our readers through the ML-5512nd product specs, build, design and more with plenty of photos from our lab. Not enough information to make a purchasing decision? Check back soon for our full review where we share the results from our review tests!
In the case of the Samsung ML-5512nd, high functioning can also mean heavy; you’ll want to unpack the printer with a second person and find a strong surface to place the printer on. This is not meant to be a desktop style laser despite the fairly compact standard dimensions (18 x 17 x 21 inches).
Dimensions will vary for medium to large businesses that decide to take advantage of paper handling options because the ML-5512nd run with four additional cassettes or with two additional cassettes and a 2,000-sheet high capacity feeder caster base for a maximum paper capacity of 3,660 sheets. You can also upgrade by adding a finisher with stapler or a four slot mailbox.
The ML-5512nd has a large output tray (maximum 1,000 sheets) on the top of the device with the control panel residing on the front. The control panel features a four line LCD, four directional navigation wheel, alphanumeric keypad and five quick keys (including the Eco Mode button).
Lift up under the control panel to access the consumables. The ML-5512nd uses a two piece set with a toner cartridge and imaging unit. Samsung offers three toner yields: standard capacity up to 10,000 pages, high capacity up to 30,000 pages and a third extra high capacity up to 40,000 pages. The imaging unit has a standard life of 80,000 pages.
Both the 100-sheet multipurpose tray and standard 520-sheet paper cassette can be accessed via the front of the device. You’ll also find a front side USB port just above the multipurpose tray handle.
The ML-5512nd comes with a 700 MHz Dual Core processor and 256MB of memory standard. Users can purchase additional memory/hard disk drive. You’ll find access to memory on the left side of the device. All other connections are located on the back of the printer as well as a removable panel for access to the paper path.
ML-5512nd Specifications:
  • Single function monochrome laser
  • Print speeds: up to 55 ppm
  • Print resolution: up to 1200 x 1200 dpi
  • 4-line LCD, front side USB
  • Automatic duplexing
  • 700 MHz dual core processor, 256MB memory standard
  • Monthly duty cycle: up to 300,000 pages
  • Paper capacity: 620-sheets standard (3,660-sheets maximum)
  • Connectivity: Ethernet, USB 2.0
  • Operating systems: Windows, Mac OS, Linux
  • 12 month warranty
  • Energy Star compliant
Pricing and Availability
The Samsung ML-5512nd is available now at the starting price of $1199.99 through Samsung or an authorized reseller/dealer.
Accessories can also be purchased through Samsung or authorized resellers. A standard capacity cartridge (10K) retails for $179.99, high capacity cartridge (30K) comes in at $269.99 and the extra high capacity (40K) comes in at $315.99. A replacement imaging unit was priced at $169.99 (pricing for consumables taken from Samsung’s website as of publish date).
The ML-5512nd comes with a 12 month warranty on both parts and labor. Get an additional three months on your warranty when you register your product with Samsung.
