Lexmark Interpret first look
by Reads (3,376)
The Lexmark Interpret is one of eleven all-in-one inkjet printers launched in late 2009. The Interpret is a budget friendly addition to Lexmarks inkjet line with print, scan, copy and fax capability as well as a 35-sheet ADF, built-in card reader, and wireless connectivity for a suggested price of $129.99.
Today, we have a hands-on first look at the Lexmark Interpret including detailed specs, an overview of build and design and plenty of photos. Not enough information to make a purchasing decision? Come back soon to read our full review!
INTERPRET SPECIFICATIONS:
  • 4-in-1 device: print, scan, copy, fax
  • Print speeds: up to 33 ppm in black
  • Laser quality print speeds: up to 10.4 ppm
  • Print resolution: up to 4800 x 1200 dpi
  • 35-sheet ADF
  • Built-in memory card reader with PictBridge port
  • Paper capacity: 100-sheet rear loading tray
  • Monthly duty cycle: up to 5000 pages
  • Connectivity: Wi-Fi, Hi-Speed USB 2.0
  • Energy Star certified
  • 3-yr limited warranty with registration
BUILD AND DESIGN
The Lexmark Interpret is smaller and slightly more compact than its big sister, the Prestige. The Interpret’s dimensions are about 8 x 19 x 13 inches when folded up but with the output and rear paper tray extended the dimensions are about 12 x 19 x 21 inches.
The Interpret also has a different design than the top of the line models. Its slightly less stylish without the large touch screen control panel and mix of black and silver. The Interpret is mostly done in matte black with a light gray top panel and a silver Lexmark logo on the top left corner. All in all, it gives off a more efficient, home office vibe.
The 35-sheet automatic document feeder (ADF) is found on top, and is the only piece on the Interpret done in glossy black. The ADF is compatible with documents ranging from A4 to letter to legal sized.
Beneath the ADF, the user will find the 48-bit CIS flatbed scanner. The scanner on the Interpret has a scan resolution up to 1200 x 2400 dpi and can scan media up to 8.5 x 14 inches.
Lift the printer just above the control panel to access the inside of the Interpret. This is where you will load the four individual Lexmark 100 or 100XL cartridges (CMYK).
The large, adjustable control panel really gives the Interpret the office look thanks to a one line display, numerical key pad (for faxes), and only a few simple quick keys.
The built-in card reader is to the right of the control panel. The Interpret is compatible with the following media: Memory Stick, Memory Stick PRO, SD, MMC, xD (Type M, Type H), PictBridge enabled digital cameras, and USB flash drives.
The six inch extendable output tray can hold up to 25 pages or 70 gsm bond while the rear tray capacity is 100 pages, 20 pounds, or 75 gsm bond. The rear tray has adjustable paper clasps for supporting a variety of media including: envelopes, cards, legal, letter, photo paper, or any media up to 8.5 x 17 inches.
Users will find all connection ports on the back of the Interpret.
PRICING AND AVAILABILITY
The Lexmark Interpret S405 Wireless All-in-One printer is available now on Lexmark.com for the sale price of $99.99. The suggested retail value is $129.99.
All supplies and accessories can be found on Lexmark.com as well. A set of four standard capacity 100 cartridges will cost $43.98 while a set of four high capacity 100XL cartridges will cost (when purchasing color combo packs) $74.98.
