Brother MFC-J4510dw Review: First Look
by Reads (4,425)
Brother introduced their new Business Smart Series geared towards – you guessed it – small businesses, workgroups and home offices earlier this fall at an exclusive event in NYC.
The lineup consists of three all-in-one inkjets that will “deliver ultra fast print speeds and the world’s slimmest depth”, but we’ll be reviewing the flagship MFC-J4510dw, the first configuration to be released to customers.
The MFC-J4510dw offers prints up to 11 x 17 inches despite the compact footprint, which Brother claims is 35 percent less than competitor’s models. Other new features include: 3.7-inch Swipe TouchScreen Display and TouchPanel, 20-sheet automatic document feeder, automatic duplexing and both wired and wireless connectivity.
So take a glimpse at our hands-on first look of the Brother MFC-J4510dw and make sure to come back soon for our full review!
The Brother MFC-J4510dw is definitely slimmer than previous generations but I’m not positive its footprint is 35 percent less than competitor’s models. I’m going to do some research on the footprint of all-in-ones in the same class and share it in our full review. For the record, the MFC-J4510dw comes in at 19 x 11 x 7 inches in non-use and weighs 20 lbs. without consumables.
The design is interesting with a mixture of gray and black paneling centered around the touch control panel with a 3.7-inch touchscreen. Adjacent to the control panel is the built-in memory card reader and front side USB port, hidden behind a small panel.
While it may not look like it at first glance due to the flat top and thin form factor, the MFC-J4510dw does offer a 20-sheet ADF for scanning, copying and faxing multi-page documents quickly and easily. The 8.5 x 11.7 inch flatbed scanner is located directly beneath the ADF.
The MFC-J4510dw offers customers the ability to print documents and images up to 11 x 17 inches thanks to a single sheet rear fold out tray found on the back of the device. The 150-sheet paper tray found on the front of the device can accommodate media up to 8.5 x 11 inches.
I love that manufacturers are starting to use a front loading ink system with Brother being one of the first to offer this easy to use feature on their all-in-one inkjets. The MFC-J4510dw uses four LC103 ink cartridges (CMYK) and offers high yield and super high yield ink replacements.
You will find all the connections (minus the attached power cord) by lifting up at the middle of the MFC-J4510dw. On the back of the device you’ll find the previously mentioned single sheet 11 x 17 inch rear tray and access to the paper path.
MFC-J4510dw Specifications:
  • 4-in-1 inkjet printer: print, scan, copy and fax
  • Print speeds: up to 20 ppm in black, 18 ppm in color
  • Print resolution: up to 6000 x 1200 dpi
  • 3.7-inch Swipe TouchScreen w/ TouchPanel
  • Web-connected applications, Mobile apps
  • Built-in card reader with front side USB
  • 11 x 17 inch rear tray
  • Automatic duplexing
  • Monthly duty cycle: up to 13,000 sheets
  • Paper capacity: 150-sheet paper tray, single sheet tray
  • Connectivity: USB 2.0, Ethernet, Wireless
  • Operating systems: Windows, Mac OS
  • Energy Star qualified
  • 2-year limited extended warranty
Pricing and Availability
The Brother MFC-J4510dw Business Smart Inkjet All-in-One is available now through authorized retailers for the suggested retail price of $199.99.
You can purchase replacement ink cartridges from the same authorized retailers. Pricing will vary.
The Brother MFC-J4510dw comes with a 2-year limited warranty.
