Brother HL-5470dw Review: First Look
by Reads (3,097)
Brother introduced nine monochrome laser printers geared towards small office environments earlier this summer. We reviewed the Brother HL-6180dw and now it’s time to check out the HL-5470dw, the middle option in the single function HL-5400 series.
All three configurations in the HL-5400 series offer print speeds up to 40 ppm, a print resolution up to 1200 x 1200 dpi, automatic duplexing, 250-sheet tray with a 50-sheet multipurpose tray, a monthly duty cycle up to 50,000 pages and a 400 MHz processor.
The HL-5470dw offers a standard memory increase – 128 MB over 64 MB on the base HL-5450dn model – as well as standard wireless connectivity and a one line backlit LCD.
Learn more about the HL-5470dw by reading out first look with plenty of information on build, design, specifications and more! And don’t forget to come back soon for our full review!
Build and design
If you read our Brother HL-6180dw review, you’ll notice that the HL-5470dw and the HL-6180dw share nearly identical designs with the latter receiving a larger (500-sheet) paper tray, adding an inch to its height. The HL-5470dw’s approximate dimensions in non-use are 14 x 15 x 10 inches but you need to consider the front side multipurpose tray when placing the printer in your office.
The box itself is fairly durable and offers little frills with only a simple control panel consisting of a 1-line backlit LCD, seven quick keys and two LED lights for standalone use. You won’t find a front side USB port but I was prepared for that since neither of the higher end models ? the HL-5470dwt or HL-6180dw ? came with this feature.
To access the two-piece consumable set – a 3,000 page yield standard capacity toner cartridge and a 30,000 page yield drum unit – you only need to press the small button located at the end of the 150-sheet output tray. Brother offers customers two replacement cartridge options: the standard capacity mentioned above and an 8,000 page yield high capacity cartridge.
The HL-5470dw has a decent sized 250-sheet paper drawer and a 50-sheet multipurpose tray, but customers with decent print volumes might consider the optional 500-sheet drawer.
As I mentioned earlier, the HL-5470dw features built-in wireless as well as wired network or Hi-Speed USB 2.0 connectivity. However, if you set up the HL-5470dw over a network connection, customers can access a variety of mobile applications including Apple AirPrint, Google Cloud Print, Brother’s iPrint&Scan, Cortado Workplace or Wi-Fi Direct.
HL-5470dw Specifications:
  • Single function monochrome laser
  • Print speeds: up to 40 ppm
  • Print resolution: up to 1200 x 1200 dpi
  • Automatic duplexing
  • 400 MHz processor with 128MB of memory standard
  • 1-line backlit LCD
  • Mobile printing: AirPrint, Google Cloud Print, iPrint&Scan
  • Monthly duty cycle: up to 50,000 pages
  • Paper capacity: 250 sheet drawer, 50-sheet tray standard
  • Connectivity: Wi-Fi, Ethernet, USB 2.0
  • Energy Star qualified
  • Operating systems: Windows, Mac OS, Linux
  • 1-year limited warranty
Pricing and availability
The Brother HL-5470dw is available now through authorized vendors for the suggested retail price of $249.99.
Supplies and accessories are available through the Brother Mall and authorized vendors. Pricing found on the Brother Mall was $76.99 for standard yield toner cartridge and $124.99 for a high yield toner cartridge. A replacement drum unit was priced at $159.99.
The Brother HL-5470dw comes with a 1-year limited warranty.
